connect plc using modbus with labview
dear ryan
i already have tried thoes example the first link is just giving a simulated sine waves and even the plc is not connected labview will still show a simulted sine wave and does not show any connection with plc and the other is example is based on ethernet and my plc is not supported
Message 21 of 25
(1,345 Views)
hiii, i am doing the communication between mitsubishi FX-plc and the labview ,.. but it will nt work and im tried a lot.. can any one help me out??????
Message 22 of 25
(1,249 Views)
can yu help me out to solve the OPc pblm.. actually im doing the communication between Mitsubishi FX plc and the labview
Message 23 of 25
(1,248 Views)
Are you using a ModBus library?  If so, which library?
What type of connection is the ModBus using?  Serial?  Ethernet?
Do you have any code you could share to help us help you?
Message 24 of 25
(1,243 Views)
actually im doing the serial communication and as well as ethernet communication using MC (mitsubishi) Protocol.
my comport is validate in serial part bt further no communication happened??
Bt in ethertnet our device is not reconised means validation is unsucessfully.
using norma DB 9 male and the female to USb converter.
Message 25 of 25
(1,239 Views)
