connect to a NI-PXIe 1078
I would like to connect to a NI-PXIe 1078 data acquisition system with an Ethernet cable through my computer (NI-PXIe 8135),
the problem is that I can not cofigure any board on the system and when I want to create a program in LabVIEW (a program for data acquisition) he does not find any card for data acquisition.
I have attached 2 pictures of NI-MAX.
(3,313 Views)
Hi RaresRumania!
I see that you can see your cards and your chassis. I wuould like you to please try Reseting your NI MAX Database AFTER you Save your Database. This is because when you reset it you will lose your tasks and scales. I would also like you to try Restarting your services.
Hope this comes in handy! have a great Day.
(3,280 Views)
Thank you very much!:)
(3,230 Views)
You are very welcome! Could you connect to your PXIe 1078?
(3,168 Views)
