connecting RS 232 serial port to USB
how to connect RS 232 to usb in labview. can any one give example for this. i have collected data using read and write visa by selecting COM3 port. it is showing that the data is interrupting. i am using labview 8.2 version for collecting data.
(3,554 Views)
usb is just the same as non-usb, or your usb to serial controller is one of the few that don't act well.
With good hardware it should function as a built in port.
But maybe com3 is your infrared port, and not your usb controller. did you check in the device manager?
greetings from the Netherlands
(3,531 Views)
i have checked in device manager. COM3 is a usb to serial port converter. how to control data. can you draw a block diagram and send me.
(3,525 Views)
Hi
use
C:\Program Files\National Instruments\LabVIEW xy\examples\instr\smplserl.llb\Advanced Serial Write and Read.vi
and play with it
(3,507 Views)
