connecting cRIO 9074 to PC. (limited or not connectivity network)
Hello.
Today i tried to connect cRIO 9074 to my laptop.
But MAX couldn't see it.
Then i discovered that the Ethernet driver in the laptop was not installed. After I installed the driver new network connection appeared in the tray, but it signed limited or not connectivity
In addition, when i check its status the IP address is not 0.0.0.0 even when IP Reset DIP switch is on.
What can be the problem and how can I solve it?
Thanks!
(7,443 Views)
Check out this Knowledge Base Article
"Why does my cRIO Not Show Up in MAX"
This doc is a general troublshooting guide that will help you connet to your cRIO. It this doesn;t solve the issue repost.
(7,422 Views)
Hello.
I have already read that.
First i discovered that i have to to use crossover cable. But the connection is still limited or not connectivity. Then i updated NI RIO driver to 3.2.1, and now it is appears in MAX, but the connection is still limited or not connectivity. And it can't see the NI9201 slot that is connected to the cRIO.
WHY?
Thanks.
(7,412 Views)
You will not be able to see the modules from MAX. You need to set up your LabVIEW project, add the CRIO as a New target then you can auto discover the modules. Other then the limited or no connectivity notification is anything not working as expected?
(7,397 Views)
Hello.
A regular project or Real-Time Project?
Do I must have RT module to work with cRIO?
(7,389 Views)
Accepted by Tacchi
Yes, in order to use cRIO you must have the following:
LabVIEW Real-Time
NI RIO Driver
LabVIEW FPGA (Optional if using Scan Mode)
Check out "Getting Started with Compact RIO" as a good guide through all of your first steps.
Message Edited by Hueter on 01-04-2010 10:00 AM
(7,347 Views)
