connection error while connecting TCP/IP through NI MAX
 As per the image attached, I am trying to connect PC1and CRIO9074 with my laptop through ethernet. I already set the IP for CRIO and PC1 & my laptop as per image attached.
CRIO is connected very well, I can access all data of cRIO9074 but when I trying to connect PC1 through ethernet in NI MAX but its showing error(I want to connect PC1 for data sharing using shared variable).
I check the IP of PC1 by pinging in my system, its working well & no data loss but still unable to connect thorough NI MAX.
Thanks for help and suggestions.
Mukesh
(1,499 Views)
Did you setup NI-VISA Server on 192.168.0.7 as described on https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIFCCA4  ?
(1,459 Views)
I tried it but still unable to connect to the system, its connected while pinging but not showing in NI MAX still.
Further guidance/suggestions.....thanks
(1,445 Views)
