control HP / Agilent 3499x with RS232
In the instrument driver network, I fould a "driver" that show how to operate an HP / Agilent 3499B switch using GPIB in LabVIEW.  Problem is, no GPIB on my system.  Is there an equivalent "driver" / example VI that shows how to control a 3499 switch using RS232 and LabVIEW?  (LabVIEW 7.1 compatible perfered or 8.0)  Thanks.
(4,149 Views)
Accepted by topic author mjg244
Since it is an IVI driver, you would need to have LabWindows/CVI in order to modify it.
A switch is a generally a simple instrument. You can write your own driver or use the Instrument I/O Assistant. I would recomend using MAX or Hyperterminal to test communication before writing any code.
(4,142 Views)
