control konica minolta T-10 illuminance meter using labview
Does any body have any ideas about controling a Konica Minolta T-10 illuminance meter using Labview. It uses RS232C USB connector. I already put the serial setting (baud rate, bits, etc) but it can't read the data. The error I get is
Warning 1073676294 occurred at VISA Read in Untitled 1.vi
Possible reason(s):
VISA: (Hex 0x3FFF0006) The number of bytes transferred is equal to the requested input count. More data might be available.
I also noticed that the instrument needs to be connected to computer. The USB connected doesn't mean it has been connected. In the original software, there is a command to connect it to computer. But I have no idea to do it in labview.
Thank you.
Aris
Message 1 of 1
(1,233 Views)
