control multiple instrument via a single port rs232
How can I connect from single rs232 port to multiple temperature controller that has a different addres for each. does it possible?
(4,703 Views)
moshez,
What communication standard do the temp controllers support?  If each controller has it's own address, it implies that they don't support RS-232.
(4,694 Views)
probably you have an rs485 connection
greetings from the Netherlands
(4,680 Views)
(4,660 Views)
Accepted by topic author moshez
I have done it with these. Knowing what position the switch is at is important in order to send the correct address bit. Tricky but do-able.
Message Edited by Broken Arrow on 09-03-2009 03:25 PM
Richard
(4,656 Views)
...and there are devices that can split up 1 rs-232 interface into more rs-232 interfaces. With a protocol like ModBus you can address one device and control the data traffic with one master.
Message Edited by K C on 09-04-2009 08:47 AM
(4,632 Views)
