control trendnet camera with Labview
Hi, I am trying to use Labview to control pan/tilt of Trendnet TV-IP410 camera, and to see the video in Labview.
I installed the SDK from Trendnet, but its not work at all in labview. I used activeX container, and inserted "CamControl",then the property node. When I run the program, it just run, and stop, but no image or camera movement at all.
Does anyone have the experience using the trendnet camera?
(3,783 Views)
As National Instruments does not offically support the SDK from Trendnet specifically, there has been no benchmark testing done at NI with this camera. I would try calling the camera manufacturer to check for compatibility issues with the SDK and for general information on image acquisition from the camera using ActiveX.
Vivek Nath
Machine Vision
(3,763 Views)
