control via Ethernet
Hi Everybody,
An instrument which has LAN input was connected the internet and was seen in the MAX. When I opened the test panel in the MAX, error was given. VISA:  (Hex 0xBFFF003E) Could not perform operation because of I/O error. How can I overcome the error? Also, in the test panel, transmit buffer and receive buffer are zero. Do the buffers have to be zero?
Thank you.
(3,245 Views)
Did you follow these instructions to set up your device in NI-MAX?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gXCAQ&l=en-US
T. Le
Vision Product Support Engineer
(3,205 Views)
