controlar equipo
estimado, con esta configuración el programa realiza lo que necesito. El ordenador, envía un dato de temperatura a un instrumento, el cual obedece al dato entregado por el ordenador.
Muchas gracias por la ayuda 🙂
Nota: tengo que configurar una conexion ethernet...¿Por casualidad me podria orientar con respecto a una conexion entre instrumento y ordenador, a traves de cable ethernet, pero no haciendo uso de la red de internet? De ante mano gracias.
Message 11 of 20
(2,654 Views)
Sorry, Google translate does not make any sense to me. Please post in English or use the Spanish board for you question.
Message 12 of 20
(2,649 Views)
Dear, with this configuration the program it does what i need. The computer sends a data of temperature to a instrument, it reads and obey.
thank you for your help! Smiley Happy
Note: Now, i have that configure a connection type ethernet...¿You can guide me? Is a connection computer-instrument via wire ethernet but not using red internet...
Message 13 of 20
(2,644 Views)
I would recommend that you use a dedicated Ethernet port on your pc. Plug it in and see if MAX automatically recognizes it. Otherwise, follow the instructions in MAX to add a tcp/ip resource. The ip address of your dedicated port should be set to the same subnet that the instrument is set to.
What is the make and model of the instrument? Have you searched for an existing driver?
Message 14 of 20
(2,637 Views)
for the test, i,m using the instrument AMETEK RTC-157, i not find drivers for this instruments.
I'm using TCP and see...
Message 15 of 20
(2,631 Views)
Why use tcp function instead of VISA? Does it appear in MAX? The syntax of the command does not look correct. It's completely different than the serial interface.
Message 16 of 20
(2,625 Views)
Because i do setting a connection via ethernet where send datas of temperature from the computer to instrument.
Not use MAX, only connection for TCP
¿why the syntax? don´t understand 😞 ...
Message 17 of 20
(2,603 Views)
Syntax - the format of the command you are sending. You are sending just a number, no prefix, no termination character. Attach the programming manual.
If the instrument is VXI-11 or LXI compliant, you should be using VISA.
Message 18 of 20
(2,592 Views)
I don´t find that information. Can connect computer with instrument which register address IP and is recognized for the computer, send test ping for DOS and port ethernet is ok! but i have problems with port assigned for computer and syntax to data...
Message 19 of 20
(2,573 Views)
If you don't have the programming manual, there is nothing you can do. You just can't make up what you are writing to the instrument.
Message 20 of 20
(2,570 Views)
