controling agilent E4990A impedance analyzer using USB & labview
I have downloaded the driver of E4990A,Now,I can control it to set the Measurement parameters,and some marker parameters.There is the value on the  impedance analyzer.But I cannot to read the value from impedance analyzer on the PC with the simple example code.its value will be 0 or 9.91E37.
The code is the picture .it is the  example code of e4990a,but it does not work.My problem is that the last read value VI do not read value.The value in labview is 0,but there is the value in the e4990a impedance analyzer.
can u help me please? thank you!
Message 1 of 1
(2,576 Views)
