controlling Xantrex
Just because you don't get an error with the VISA Write, does not mean it is working. You could have you cable connected to nothing at all and you won't get an error with the VISA Write. Usually, the reason you get a timeout error with a VISA Read is that the instrument is not sending any data and usually this is because it is not receiving the correct command. Please verify that you can use Hyperterminal.
Message 21 of 26
(1,488 Views)
ok, I understand this.
I try Hyperterminal now.
Message 22 of 26
(1,484 Views)
actually I can't type in the hyperterminal-window
What am I doing wrong?
Message 23 of 26
(1,480 Views)
Sounds like you might not have any connection to the instrument. Check your cable. There are two types of serial cable. A null modem type crosses the transmit and receive lines (2 and 3 on a DB9) and the other has the lines wired straight through. Use an ohmeter to check which type you have and compare it to what the manual says you should be using.
Message 24 of 26
(1,476 Views)
Hi everyone,
actually I had a wrong cable. Some one must have changed it during the delivery to me. That is really really bad.
I would like to thank you all for taking so much time to solve this problem. I'm so sorry for that, but everything works out fine now.
Kind regards,
physics2007
Message 25 of 26
(1,471 Views)
I am glad to hear that things are working well now.
Cheers,
NathanT
Message 26 of 26
(1,457 Views)
