controlling oscilloscopes delay
hello!!
I ve got some questions. i use a tds 3250 scope and i 've downloaded the drivers. How can i contol the horizontical delay as a percentage (for example 10%); furthermore is there a way to pass in labview a setup of the scope that i have made manually;and somethin else. How can i save a waveform from the scope in a file through labview; both the x and the y values...thanks a lot!!i wait for your answer..
(4,695 Views)
I don't think there have model # tds3250.
you may recheck it. which driver you did downloaded?
(4,664 Views)
Yes!My fault..it's tds 3052..thanks..
(4,660 Views)
so, any advices;;;
(4,654 Views)
Have to write your own VI.  Reference to the Programming Manual of TDS3052. (My Driver Revision Date: 04/30/2008)
HORizontal:DELay:STATE  OFF
and.
HORizontal:TRIGger:POSition
No. But, as I know the setup of this scope was stored as SCPI command. you may send it back to the scope.
Use the  Single Channel waveform acquire.
(4,644 Views)
Is it easy to give me  alimk for this driver references;; i cant find them..thanks..
(4,626 Views)
i mean "link"...is there any already fixed vi fir this operation;;
(4,620 Views)
