conversion of array of results from string to numerical format in labview.
hi, i am interfacing keithley 2612a with pc using gpib and labview. i am receiving my results(numerical) in string format after giving commands to machine in string format(which is required to do ). now whenever i try to convert the results in numerical format by applying 'string to num. format', it shows only one result rather than array. i am receiving my results collectively in a form of array. please tell me a way to convert this string array into numerical format. i am using labview 7.1.
(3,700 Views)
first learn LabVIEW and drivers
greetings from the Netherlands
(3,697 Views)
Can you share some code so we can see what you have tried?  How about an example of what you are recieving and what you expect out?
(3,693 Views)
You'll want to read what he wrote in another relevant thread.  http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/keithley-2612a-interfacing-with-pc-using-labv...
(3,688 Views)
thnx for considering the question, guys! i sorted it out.
(3,671 Views)
