convert ascii from serial port to decimal
Hey SCMAJA,
You can actually do a simple conversion by using the Type Cast function. This is located under the Functions Palette->Mathematics->Numeric->Data Manipulation. You have to use an I32 as the input and the output can be a simple string, the default type to convert to is string.
Hope this helps
Message Edited by Can W on 11-15-2007 11:10 AM
Can Wong
Message 11 of 12
(1,088 Views)
Thank you, got it to work Smiley Happy
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
Message 12 of 12
(1,082 Views)
