csi8d
I am looking for labview driver to the CSI8D o CSI8DH temperature controller. They are from OMEGA and I can fine drivers in NI Driver Network.
(3,742 Views)
Did you tri on the omega website to check if they got it?
Probably you can contact the manofacturer technical support for that....
As you said there isn't that driver on our network so probably is not tested, verified by NI.
Jaime Cabrera
NI Applications Engineering Spain
(3,727 Views)
Yes I was in Omega site..they dont have any drivers for thi CSI8dserie.
(3,722 Views)
If you have the RS-232 serial options, I sure it would be a pretty simple command set that is in the manual. Use basic serial read/write vi's to create your own driver.
(3,717 Views)
Yes I have the rs232 option but I have a lot of to programm and was looking for drivers just programmed and tested...
(3,704 Views)
