current graph 2400
Hi, I need a simple and basic program but I cannot find it.
I have a Keithley 2400, I simply apply a voltage on a resistance R.
I need a Labview Program by which I can enter the voltage level and the program plot me the current that the Keithley acquire.
Stop no other.
I have both a gpib than serial.
Can someone give me a suggestion about a already done program?
Thank you.
G
(3,783 Views)
You can find the LabVIEW driver here. If you would do a simple search for '2400', you will find numerous posts. Some have example code.
It's unlikely that you will find a complete program that does everything that you need and no one is going to do your homework for you. The program to do this is not that hard.
(3,777 Views)
many thanks
(3,768 Views)
