cwserial
Hi!
I have some difficulties using the CWSerial ocx component. I want to use it under Visual J++ (6.0), it's test possibility (on the Properties's test panel) works fine, I can send and receive data, but when I want to use it's methods, it doesn't work (the problem can be in using the Variant datatype). Can you send me a short VJ++ example that sends and receives data from the serial port?
Thank you in advance!
Steven Racz
Software Developer
GE Hungary
(3,650 Views)
Hi Steven,
The ComponentWorks controls were not intended to be used in Visual J++ or to be used with the Java language, but since Visual J++ does allow you to insert COM objects and ActiveX controls into your forms by doing a lot of things behind the scenes for you it may be possible to make them work.
Here is a guide on the Microsoft Developer Network (the definitve source for usage issues of the Microsoft IDEs) that talks about calling methods of COM objects and ActiveX controls:
http://msdn.microsoft.com/library/devprods/vs6/visualj/vjcore/vjovrprogrammersguide.htm
On a final note you should be aware that since Visual J++ has to interface the native code of an ActiveX control with the Java language there may be some complications, and National Instruments doe
s not provide support for technical issues/complications of using ComponentWorks in Visual J++.
Jason F.
www.ni.com/ask
(3,650 Views)
