dS2824 - 24 x 16A ethernet relay control through labview
Has anyone controlled dS2824 - 24 x 16A ethernet relay through labview. If controlled please share me procedure with some examples.
Thanks in advance
(3,502 Views)
Is your boss willing to pay for provided code?
(3,442 Views)
You may have to program it yourself.  They have their own software but I assume you want to integrate it into LabVIEW.   Open a VISA Socket connection to the devices and write and/or Read commands using VISA Write and VISA Read.
LabVIEW ChampionLabVIEW Channel Wires
(3,437 Views)
The manual seems pretty clear on how to set up the device and the commands to write to it.  Personally, I would set it up to use the ASCII commands and it is quite simple from there.
(3,433 Views)
@crossrulz, exactly.  The hardest part will be to set up the networking either as a private VLAN or on the public network with a DHCP.  The communication is just ordinary command/response.
It appears to use port 17123 (according to a figure, but not documented!!) and default to an address of
192.168.0.123 so you need to make sure that your computer is on that subnet unless you have a local DHCP server.
then just use a visa address of TCPIP::192.168.0.123::17123::SOCKET and off you go!
(3,431 Views)
