daq ass.
hi,
we r having the problem performing the 4th exercise of the getting started manual labview 7.1.
the problem is that in daq assistant configuration the analog input> voltage>..,we have the problem in supported physical channel. we r not able to get the dialog box of list of channels on daq device. here is it necessary to connect some physical instrument to perform the exercise.
plz give detail description.
(3,151 Views)
You have to have a DAQ board in your system in order to use the DAQ Assistant. Do you have one?
(3,143 Views)
