deploy license
1. If I develop an application with Visual Studio while using the NI-4882 adapter and my app contains some of the NationalInstruments.*.dlls specifically NationalInstruments.Common and nationalinstruments.Visans.dll and nationalinstruments.ni4882.dll, can I release that application publicly?    I will indicate that they would need the NI-VISA runtime and mention if they have an NI4882 then that is free otherwise they need to pay NI for the runtime.  is this correct?
Thanks!
(6,182 Views)
So for example if the user downloads the software and they have instruments connected via USB(instead of GPIB using NI-GPIB) can they use the application or would they need a license or do I need a license to allow them to use it, please clarify how they could get the runtime with regards to licensing.
I assume nothing would need to be done in the case where the user has ni-hardware is that right?
(6,176 Views)
(6,158 Views)
Thanks Dennis.
Let me be more specific.   Can I distribute an application that contains only the VIsa api libraries, the 3 that I mentioned above?  My users are expected to have the relevant NI-VISA drivers/hardware from NI.  I am not giving the runtime for NI-VISA.   The instrumentation functions of the application are useless unless they've got the nI hardware/software themselves.  So it would seem that this is ok since I'm not giving the NI-VISA software/runtime and those who are using it are the ones who have NI-hardware which would give them the right to use it.  Let me know if I'm incorrect.
Amiel
(6,134 Views)
If you are confused, contact NI. As I see it is not relevant as I'm not a lawyer and not an NI employee. My opinion is that a license would need to be purchased if the end user is not using any NI hardware such as with USB.
(6,128 Views)
