difficulty transferring stored data from
Hello I am having difficulty transferring stored data from the readings of the ph meterinmeter orion Star a211 using hyperterminal memory data
(2,844 Views)
Hey FabioBrasil,
Thanks for reaching out the NI Forums.
Could you give us more details on the problems your are facing? Here are some questions that can guide you:
  • Are you getting any errors? Can you share the error messages?
  • The data is not being transferred from your device to your computer?
  • Are you using a LabVIEW instrument Driver?
  • Have you tried the examples that come with the instrument Driver?
Cheers,
Felipe Flores
Technical Support Engineer
(2,803 Views)
