display dot matrix
Hi All
I got this dot matrix message board but i am trying to find software to get text onto it through serial port ( USB >>serial port )
the board is : FRENDS model:FDS43
Does anyone know pls?
I tried Terminal, Tera Perm but no luck so far 😞
Greetings
(4,756 Views)
Anything to do with NI hardware or software? I'm not sure what sort of help you expect here. A Google search did not turn up anything, you did not provide a link, you did not provide a manual, you did provide any information on how it's connected, you did not provide the command you are sending, etc. What does the vendor have to say?
(4,751 Views)
