dmm 4065 external trigger pull down
does the DMM 4065 external trigger input (aux port on card front) require a pull down for a postive edge trigger?
(4,705 Views)
issue closed-
(4,664 Views)
@mikeatbosch wrote:
issue closed-
And what was the answer?  Somebody else might have this question and it would be helpful if you gave the solution you found here.
(4,660 Views)
misunderstood the external trigger, it is a pure digital input-rise time important, so I had to use a arb to simulate a actual digital input for just debugging the code.  The final set up wil use an digital output from  a daq card.
Mike
(4,653 Views)
