driver Agilent 86120C
I can't find Labview driver (VI file) for Agilent 86120C. Any one can help?
(3,565 Views)
There's a CVI driver here. It actually includes a LabVIEW llb. The VIs are wrappers around Call Library Function Nodes that call the CVI dll. I'm sure this llb was created by the old import CVI driver tool. The VIs are in LabVIEW version 5.1 so if you have LabVIEW 8.5, you will need to open and save the llb with a version other than 8.5 first. You could also use the latest Driver Import Wizard and create a LabVIEW driver yourself.
(3,558 Views)
