driver agilent power source 6811b/6812b
we are using Labview 8.0.1 and want to use a 6811b AC source via GPIB.
Does anybody have a driver for this source ?
Maybe a driver via RS232 would also help, but GPIB is definitly preferred.
Remark:
drivers for 6812B model might also work due to the difference is only the output power capability
Thanks a lot in advance !
Robert
(4,314 Views)
There's a 6812A driver available on the Instrument Driver Network. You can also do a search from LabVIEW. Use Tools>Instrumentation>Find Instrument Drivers.
(4,307 Views)
the 6812A is an analyzer, no AC source - perhaps you have another idea how to solve this issue.
regards
Robert
(4,277 Views)
The link say AC Power Source / Analyzer
Regards
Ray Farmer
Regards
Ray Farmer
(4,272 Views)
Hello Robert,
    I also highly recommend that you give the driver a try.  Depending on how the Initialize VI is coded, you might need to either disable the ID Query OR add the 6811B and 6812B to the array of strings listing the supported models.
Let us know how it goes,
NathanT
(4,260 Views)
