I'm looking for NORMA d5155 power analyzer. Where it possible to find it. If i try to build myself, is the best VISA,488.2,GPIB library to make teh appropriate driver? Thank's Nicola
There are not drivers for LEM/NORMA 5155 power analyzer, so you have to build a driver. You can use the VISA functions which are valid both for the GPIB protocol and that serial. You can use to help you the instrument drivers for the LEM Power Analyzer D4000 or D6000 downladable at link:
You have to study only the difference between the commands sets of the the 5155 and 4000/6000 calling LEM tech support or studing the instrument manual.
Hope this helps!
Marco Castellano Application Engineer N ational Instruments Italy
