e4418b, simple ctrl via RS232
Hi
can anyone provide a simple working example of RS232 setup parameters, and a command like *IDN?.
I want to verify the communication setup, but it's not working correctly.
The RX symbol is blinking on the E4418B whenever i send a cmd, but it's not reacting otherwise.
If i send the *TST? cmd, i would expect it to run the selftest.
When i send a MEAS1? cmd, do i have to do anything further to get the result ? like read some output buffer, or is the result send directly to my terninal program ?
br
Nikolaj
(5,068 Views)
There is an example that comes with the driver - Help> Find Instrument Drivers. After installation, use Help> Find Examples and look under Hardware Input and Output.
You could have a mismatch in communications settings, the instrument may not be configured for serial, you could be using the wrong type of serial cable. What error code/message do you get?
(5,063 Views)
is must be something with the comm setup.
I changed from "putty" to "termite" terminal and setup in same way.
However now it's working like i expected.
There must be something "hidden" in the "putty" tool
(5,044 Views)
Hidden?
More like you didn't configure Putty properly.
(5,041 Views)
Yes... hidden means just that
(5,028 Views)
If you say so.
You might as well give up.
(5,019 Views)
