I am trying to set up a VI. I ran into an issue that I have yet to solve. The piece of equipment is an Agilent E4426B. I cannot find an easy way to increment or decrement the amplitude of the signal coming out. You can do this manually on the Signal Generator, so I assume there is someway to do this programatically. If there is not an easy way to do this, I was thinking of making a table with two columns of values. If the input matches the first column, then the output would be the corrosponding second column value. Is there a way to do this in LB as well?
Thanks in advance for the help.
- Jarrod
