enet/100
I have setup up the GPIB-ENET/100.
But  I can't "scan for instrument" (power supply)
why??
Do you send e-mail to me?
THANK YOU
Message 1 of 13
(5,880 Views)
What exactly do you mean? What happens when you click the scan button? Any messages? Any error codes?
Message 2 of 13
(5,875 Views)
it show "There was an error..." in the connected instruments table.
why the serial number table show "Not available"  ,  normal??
Message 3 of 13
(5,873 Views)
The drop-down menu of General settings ,  Advanced Settings and Termination Settings show gray color and disable.........
normal?
Message 4 of 13
(5,871 Views)
That's the complete message?
What version of NI488 did you install and what os are you using?
Message 5 of 13
(5,869 Views)
os is vista  and I have install ENET/100 driver.
click the scan botton,
the error string shows "There was error ...."   only.
no work
Message 6 of 13
(5,860 Views)
I install driver =>  ni4882_311
Message 7 of 13
(5,859 Views)
I  feel I have setuped up success.
but it can't not "scan".
Message 8 of 13
(5,858 Views)
I've only used the enet controller a couple of times and that was a while ago. I would suggest trying a different instrument and if you are using a separate GPIB cable, a different one of those as well. If you get the same message, try doing a repair of the driver.
Message 9 of 13
(5,852 Views)
I have changed my PC to windowsXP
PC got a IP
but it show waring!
Message 10 of 13
(5,836 Views)
