fluke 8846a read issue
Hi all,
I have a  fluke 8846 multimeter that im using to measure temperature , i need to log the data with labview , for this i donwloaded the ni drivers for  my fluke 8846 , but whe i run the examples , more especifically the  Fluke 884X Series Read Temperature Measurement.vi  , the multimeter  makes a couple of beeps , a click sound and the lcd  refreshes , the vi stops with only one measure recorded (the last one before the blinks), i want to log the temperature in the vi as it chnages in the multimeter, i dont know what could be the problem.
I cheked the config  on the multimeter , ports on the pc and in max , im using a serial to usb cable.
whe i check with the visa test panel  , this si what i get
1: Write Operation (*IDN?\n)
Return Count: 6 bytes
2: Write Operation (*IDN?\n)
3: Read Operation
Return Count: 35 bytes
FLUKE,8846A,2428013,08/02/10-11:53\n
4: Read Operation
and some errors
Read Operation
Error
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
 whe i read the status byte
Read STB Operation
Error
VISA: (Hex 0xBFFF003A) Unable to start operation because setup is invalid (due to attributes being set to an inconsistent state).
i hope someone can  help me
thanks
driver : http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=2EF8BF6ED2A54705E0440003BA7CCD...
(5,931 Views)
There is not a status byte on a serial port.
Try \r as the terminator. You may be able to change this from the instrument front panel. I don't know what the driver is set to buy you can quickly check that by looking at the block diagram. And please provide the errors that you get with the driver.
(5,925 Views)
