fpga serial communication
hello,
i am using Crio and i am having a problem in serial communication even i flowed the exact steps from the exampls i always recive the same error which is "poly VI visa configure serial port: bad linkage to sub vi" is it a visa settup issue?? knowing that when i run NI MAX it indicates that there is a visa error under the peripheric and interfaces of my Crio.
thax in advance.
Message 1 of 11
(6,074 Views)
Hello moho,
Could you post a screenshot of the error?
Nadine H.
Message 2 of 11
(6,043 Views)
hi Nadine,
thank you for your reply, i had some configuration errors and it is ok now.
Message 3 of 11
(6,022 Views)
I'm glad to hear that you managed to resolve the errors you were seeing.
Have a great day!
Nadine H.
Message 4 of 11
(6,011 Views)
hi Nadine,
since i dont have a digital input module i tried to use the serial port RS232 on my Crio to read the data from an absolute encoder in order to perform PID control for  a dc motor, but the problem is that the data took too match time to be read; there is a big delay between the first read position and the next one, please i need help.
Message 5 of 11
(6,002 Views)
Hello moho,
How are you configuring your Serial communication?
Which example are you following?
Can you post a screenshot of your code?
Nadine H.
Message 6 of 11
(5,982 Views)
hello Nadine,
ok here a snapshot of my vi:
Message 7 of 11
(5,968 Views)
and when i tried to save the data in a file ian error occured i dont know the reason!!!
Message 8 of 11
(5,966 Views)
Hi moho,
Have you tried running any of the examples that come with LabVIEW to test this out? If so which examples? Are you getting similar behavior when you try running those?
Message 9 of 11
(5,936 Views)
HI,
i have reduced the number of bytes to read to 4, but still the same problem now some times it start working normal than began to slow down and some time it is too slow even when i change the slide controller its indicator took time to change, although it should be instantinouse.
Message 10 of 11
(5,912 Views)
