from where can I get a LabVIEW plug & play Instrument driver for TEK DSA600 ? Sir Knutson ?
we used already a downloaded Labwindows/CVI driver and tryed to convert it for use in LabVIEW, but it was not successful.
An error message came up : Call Library Function Node: library not found or failed to load.
We tried to run the tkdsa60 ReadWaveform.vi
(3,268 Views)
I have no idea where you got that. The one on the instrument driver network is not a CVI driver though it is old and unsupported.
(3,263 Views)
