get frequency and amplitude from fft module
I am trying to save the frequencies and the corresponding amplitudes of a certain signal in an array.
But I couldn't find a way to get the components of the output of the FFT Spectrum(Mag-Phase).VI
Please could you help me get the output components of the mentioned FFT VI
Thank you,
Bill
(3,493 Views)
It's a cluster so you would use the unbundle by name to get the f0, df, and magnitude array. If you really need a frequency array, use a for loop with a shift register. Initialize the shift register to the f0 value, increment the shift register value by df, and run the for loop to a count equal to the magnitude array.
p.s. This has nothing to do with instrument control. If you have a NEW question, you should post to the LabVIEW board.
Message Edited by Dennis Knutson on 04-25-2010 12:00 PM
(3,482 Views)
Message Edited by Dennis Knutson on 04-25-2010 12:06 PM
(3,475 Views)
