gpi8.lib and .dll
I have an application that needs to talk to an NI PCII/IIA GPIB board.
It works when I use the .lib and .dll that comes with the board. However,
I have other software that has to use a NI gpib.dll dated 4/24/96 and will
not work with the 10/15/93 gpib.dll that comes with the board. I have been
unable to make my application work with the newer dll. I have a gpib.lib
dated 3/6/95 that works with this dll for a CEC 8 bit gpib board but not
the
NI board. NI customer support didn't help any (though they did try). Any
help with would be greatly appreciated.
(4,058 Views)
David Petersen wrote in message <38398698@newsgroups.ni.com>...
>the
David:
It sounds like the developers of the application that uses the gpib dll
from '96 coded it to use that version of the .dll when it wa
s developed. The
93 dll is an 16 bit dll and the 96 dll is probably a 32 bit dll, which would
cause your problem. Your best bet is probably to get an AT-GPIB TNT (DON"T
GET THE PNP VERSION). Or you could contact the author of the software that
will not work. I recommend that you get a newer card if possible since most
new software requires an AT-GPIB/TNT or better to operate. I make no
guarantees with these statements, just my feeble experience with the older
cards. Good Luck
Vaughn Arthur
Test Software Designer
Grayson Wireless
E-Mail: vaughn_arthur@grayson.com
Phone: 804-386-5158
Fax: 804-386-5370
Virtual Reality: Its just like reality except you wear a hat!
(4,058 Views)
I think I have a similar issue.
I have a PC with an NI PCI GPIB board and running Windows XP.
I have legacy software that includes a NI-GPIB DLL dated 21/09/1995, which fails to load.
The software was written to run on Windows 3.1, but almost runs on XP under wowexec, except that it cannot access the GPIB hardware.
I am trying to contact the original writers of the software (Racal) for the source, so that I can port it onto a more modern platform, but what are my chances with using the pci-gpib dll instead (through some kind of translation layer)?
(3,215 Views)
