gpib USB-B card cant find instrument in application
i have made and tested an application in LV. When using the application on the laptop (which has gpib usb-b) the instrument is not able to find the device's on the bus. However when using the "measurement and automation" tool i can easily find the instrument. The error occurs after the vi "visa open" and is not know. What do i need to do?
(3,299 Views)
It could be related to the link below:
http://digital.ni.com/public.nsf/websearch/6217D314252A51168625693F004FD873?OpenDocument
If this is not the case than please specify your question. For example what exact error are you getting?
Regards.
Joris V
AE
NIBE
(3,299 Views)
Tanks for replying but i found the answer yesterday , i was using the 1.0.1 version and the cause of the problem was the visa version. I downloaded the latest and everything works fine now.
Regards
(3,299 Views)
