gpib commands agilent 8960 using ni-max
hi
i am using ni-max to send gpib commands to the agilent8960.
1. when i write the following command in ni-max SYSTem:APPLication:CATalog:FORMat? i get i responce back in ni-max from the agilent 8960 letting me know what state it is in
2. when i write the following command in ni-max SYSTem:APPLication:FORMat '1xEV-DO' i get a error message on the agilent8960 saying illegal parameter value.
do i have to send a \r or a ; in the begining of the command
this is from the agilent8960 manual        SYSTem:APPLication:FORMat[:NAME]
(4,821 Views)
You usually need to append a termination character at the end of GPIB commands, this all depends on the device itself so it might be a better question for Agilent if not stated in the manual.
(4,793 Views)
It seems the instrument is choking on the '1xEV-DO' parameter. You sure you are supposed to use ' to surround the name?
(4,781 Views)
I had a question pretty much similar to the discussion. I am trying to write a perl script to be able to communicate with the AGilent through GPIB. Is that possible at all?
Thanks for the help.
Athreya
(4,677 Views)
Hi Athreya,
NI does not officially support GPIB communication with Perl scripts, but it is possible. I have found a few links that should help you get started with that.
http://search.cpan.org/~jeffmock/GPIB/ni/ni.pm
http://www.labvisa.de/
I hope this helps!
Tanya Visser
LabVIEW Group Manager
(4,654 Views)
