gpib commands via ethernet
how can i control my device through ethernet by passing SCPI commands or GPIB commands.
The device is standalone industrial PC has laser sources.I need to control sources. The IP address is 202.10.10.2.
(4,286 Views)
You can use VISA to control an instrument with an ethernet interface. Open a connection using a resource name of TCPIP::host address and then you should be able to send your SCPI commands with VISA Write just like you would with a GPIB connection. You should also verify that it's on the LAN from MAX. Right click on Devices and Interfaces, select Create New and then select TCP/IP Resource and then follow the directions.
(4,286 Views)
You might also find these resources helpful:
http://digital.ni.com/public.nsf/websearch/D7D8E3E1B682022286256D4A00771A52?OpenDocument
http://digital.ni.com/public.nsf/websearch/80C28CC795611E4A86256AB100209521?OpenDocument
Scott B.
(4,286 Views)
