gpib driver for IDL
Are there any gpib drivers for IDL?
(6,221 Views)
Can you give a more detailed explaination of what IDL is and what it is your trying to do?
Additionally, check out https://www.ni.com/en/support/downloads/instrument-drivers.html for a 9000+ list of drivers supported by NI products.
(6,203 Views)
IDL (Interactive Data Language) is programming environment, like, e.g., VC++ .
(6,200 Views)
There is not a driver that is already built for communicating over GPIB with LabVIEW and IDL.
It is possible to use IDL with .NET C# and integrate your C# code with LabVIEW.  I would recommend looking into the IDL documentation online to see what they support.  LabVIEW does not directly support IDL.
For me to be of further help, you'll need to provide a detailed explanation of the application, software, and hardware you are trying to use.
Regards
(6,191 Views)
Thanks for the reply.
It looks like I have to do this. I just want to make sure before committing (or not committing) my time.
Yes, there are ways how to send commands from IDL, e.g., by using a call_external function.
I thought that NI should have done this already. It is disappointing... But anyway thanks again.
(6,188 Views)
