gpib driver with linux redhat 7.3
I've used a AT-GPIB card with linux RH6.2 with succes. Now I try to install it on linux RH7.3 (kernel 2.4.18)but it doesn't work but installation seems to be correct. Is the problem known?
(3,234 Views)
Hi db,
There has not been any known issues with this (yet), but what seems to be the problem? Is the module loaded correctly? Do you have the kernel source package installed? (this is necessary to build the driver)
Aaron K.
Application Engineer
(3,234 Views)
