gpib enet from java
I have a NI GPIB-ENET/100 on which I have gpib devices connected. I would like to access those devices from a Java environment on a linux (debian) machine. There is a linux driver available, but not supported for debian.
In this topic :
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/polling-gpib-enet-unit-over-tcp-ip-using-java...
it is suggested that  if I have the .so libraries, then it becomes possible from a Java environment. So where can I find those libraries ? All I found at the moment is the linux driver.
Thanks.
(5,010 Views)
As I understand, the .so library will install on your computer during the installation of the linux version of the driver. Dies it answer your question?
You will find here the last version (15.1) of the driver.
Have a nice day,
M-Junior
(4,913 Views)
Hi, Thanks for your answer,
I see, so I actually need to install the drivers on my machine and then I can do whatever I want to do with the .so libraries, like access them from java.
Thank you again
(4,898 Views)
