gpib error code 28
I have Performed a update and now i receive this error device will not connect.
(4,325 Views)
Hello Jenks,
GPIB error code 28 is a GPIB ENET error.
Does the ready light of the ENET device flash red?
There is an article in our knowledgebase that describes possible causes of this error
and potential fixes. Please read this article and perform the necessary solution steps.
The article can be found here.
Let us know if this helps.
Christian A
(4,297 Views)
this is a GPID-USB-B and code is in driver part. I am at a loss about what to do.
(4,280 Views)
Hello Jenks,
If you need the device to work immediately I would suggest downgrading the drivers.
If you want to proceed with the current driver can you check to see if your device
will work on another machine? This error only occurs if the power requirements from
 the usb bus are not being met.
Please let us know how this goes.
Christian A
(4,251 Views)
