gpib hp34401 visual basic 6
I use a HP34401 to make some voltage acquisitions.
I control my HP34401 with a VB6 application on a computer using National Instrument Driver ans DLL : NI-488.2
I want to launch several acquisitions successively on my HP34401 using for example :
SAMPle:COUNt 3 -> definition of the number of acquisitions
INITiate -> read the 3 acqusitions and save them on the memory of the HP34401
FETCh? -> read the 3 acquisition of the HP34401 memory and download them by GPIB on the computer
So in the NI module VBIB32 I use the ilrd function but it only works with a single acquisitions. I can't download several acquisitions in my buffer.
I use :
Dim S As String
Dim NbAcq as Integer
NbAcq = 3
Hdl = ildev(0, 22, 0, 12, 1, &H10A&)
... -> 'Configuration and Initialisation (No Problem)
S = Space(255)
ilwrt(Hdl, "SAMPLE:COUNT " & NbAcq & "; :INITiate", 25)
ilrd(Hdl, S, 255)
It works fine for a single acquisition.
For more than 1 acquisition I can see in the HP34401 display that several acquisitions occur and I can read them in its control panel but I can't download more than only one.
I have tried to use the ilrdi function that accept Tables but it works only with Integer and I need Double.
Can you help me please to solve my problem ?
Thanks a lot
Julien
(3,814 Views)
NI provides a wizard to help you troubleshooting  your devices, you can try to use it for your problem. I give you a link how to use the wizard:
http://www.ni.com/support/gpib/max/commutil.htm
Hope it will help you for your problem.
ClémentG
(3,762 Views)
Julien,
To read an array of doubles, you can either modify the ilrdi function prototype for integers to accept an array of doubles instead. Or you can create a new subroutine based on ilrdi.
To modify the existing ilrdi, open the vbib-32.bas module. Go to the ilrdi subroutine and change the Integer to Double, as shown below is a code snippet:
Sub ilrdi(ByVal ud As Integer, ibuf() As Double, ByVal cnt As Long)
But if you want to leave ilrdi intact, you could copy and paste the ilrdi subroutine, give it a different name, such as ilrdd, and change the ibuf to be a Double.
I would suggest copying the original ilrdi and creating a special subroutine that handles an array of doubles only.
Hope this information helps.
(3,757 Views)
