gpib pci card installation problems - card won't start
We are updating computers and now the ni pci-gpib card won't start in a brand-new hp dc5700 (xp pro) computer. It attempts to install, but it ends up with
"This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device." message in device manager
Anybody knows what may be going on?
(4,637 Views)
Howdy ealekseev,
That error code is generated if the BIOS does not correctly identify the PCI-GPIB device. An update of the NI-488.2 driver should fix the problem.
1. Power off your PC
2. Remove the PCI-GPIB device from your PC
3. Download and install the newest version of the NI-488.2 GPIB driver here: NI-488.2 download
4. Power off your PC
5. Install the PCI-GPIB device to your PC
If installing the newest NI-488.2 GPIB driver does not fix the issue, then please feel free to reply here, and I'd be happy to explore other options with you.
Warm regards,
pBerg
(4,607 Views)
I'm using an HP DC7700C PC (UK version). I'm setting it up to be deployed in the UK.
Your solution was to load the latest version (2.5) of the NI GPIB drivers, but this doesn't work for us. We are using a custom application that was written using some of the low level commands in ibconfig that are apparently no longer supported n the latest version. I don't know why you dropped them, but it has left us with no way to move forward without re-writing the application I/O.
We have been using version 2.3. I know 2.4 won't work. I would download 2.4 but I can't find it on your web site. Only the latest is available for download. Is there some way you can let me get version 2.4?
(4,596 Views)
Howdy uWave,
You can find all the available NI-488.2 drivers here
Warm regards,
pBerg
(4,578 Views)
