handling events in a while loop
In a while loop, I need to stop the loop after a change of state from false to true or true to false or I can do this by detecting a certain string from the serial port. Seems like I should be able to do this simply by using a counter which is edge triggered. Please Help.
(3,657 Views)
I would love to help but you have provided very little for me to go on.
RE: your boolean, if you recall the previous state and compare to the current using an exclusive OR operation, It should return a true when the previous and current values are different.
On the string thing, you could compare the read string with a constant and get a true when they match.
The above are simply lame ideas that may be of use. If you could go into greater detail, I may be of greater assistance.
Ben
(3,657 Views)
Hi Ben,
What I ended up doing is what you suggested. I read the string prior to the while loop to get an initial value which I then compared to the current value.
Lou
(3,657 Views)
Cool!
(3,657 Views)
