hardware help
I am checking the resistance of a post.  My parameters are 147k to 153k Ohms.  Is there anything that comes to mind to use for this situation with at least 16 bit resolution?
The device that I need has to have adjustable settings for discrete I/O to go to a device like a PLC.
I've attached a jpg of a cad drawing to make my question a little clearer.
Thank you in advance.
Ron Deavers, CLD
(3,659 Views)
Hello!
In order to measure resistance I recommend using one of our DMMs. The resolution varies depending on the product and they go from 5½ to 7½ digits. These digits refer to the number of digits displayed on the readout of the DMM and you can learn more about them from our DMM Products Page.
Let me know if you have further questions about it.
Good luck,
Tica
(3,622 Views)
Not to contradict NI's App-Ings, but all of NIs DMMs have a huge drawback from my point of view. This is, they are all 'internal', meaning they need to be installed into a computer or PXI chassis. Nowadays PCs have little or no PCI slots free and a PXI chassis is much to expensive for 'just' a DMM.
 I'd love to have a 'mobile' solution, based on USB2 or Firewire or even on a serial  connection. IMHO DMMs are not necessary for quick measurements and huge amounts of data, but for exact ones, maybe with internal triggering and internal preprocessing.  At least with my test apps It was sufficient to get some 10 readings per second if the DMM supports True-RMS and some kind of DC+AC mode.
You may look for 'B&K precision' DMMs, they have a DMM 'BK5491A', which is a programmable desktop DMM, is much cheaper and connects serially  to the computer. Or there are lots of handheld DMMs with serial  or USB connection...
Just my Euro 0.02!
Greetings from Germany!<br>-- <br>Uwe
(3,612 Views)
