hello i want to interface the YIG oscilloscope with the laptop so first what i have to do?
hello
if i am interfacing laptop with yig oscilloscope then first what i have to do?
which kind of probe is benificial for me
Message 1 of 13
(4,643 Views)
The first step would be to explain what a yig oscilloscope is (link?). Then explain the type of connection it has - GPIB, serial, Ethernet, USB, etc.
I have no idea what sort of probe would be beneficial and I would not hazard a guess as to something so personal.
Message 2 of 13
(4,636 Views)
hello,
thanks for reply, i want to connect by usb and YIG oscilloscope is designed by me to give the input to the plasma devices to genrate the input
Message 3 of 13
(4,619 Views)
@husssey wrote:
hello,
It doesn't matter what you want. It matters what connections are available on the oscilloscope.
Message 4 of 13
(4,610 Views)
You designed the scope? Then you would want to refer to this unless your USB interface already is using some defined class.
Message 5 of 13
(4,606 Views)
thanks for reply
can u send the link of driver download which will help to interface TDS3034 osilloscope with computer with windowsxp
Message 6 of 13
(4,590 Views)
@husssey wrote:
thanks for reply
I don't know what a "u" is. I do know what a "you" is, though. Please use full words, not text-speak.
All instrument drivers can be found in IDNet: http://www.ni.com/downloads/idnet/
You didn't indicate what language you're using. If you're using LabVIEW you can also use Help -> Find Instrument Drivers.
Message 7 of 13
(4,582 Views)
@husssey wrote:
thanks for reply
Now why couldn't you ask that in the first place instead of the cryptic reference to YIG?
Message 8 of 13
(4,577 Views)
thanks for reply
i am using labview for interface pc and oscilloscope,so to from where i  have to start i dont know bcz i am learning labview now days and making my project.
other device is one oscillator that also i have to interface it with pc using DAQ card
so plz guide me on this
Message 9 of 13
(4,565 Views)
@husssey wrote:
thanks for reply
You have been told before. You are not texing friends here. Learn to use proper English; bcz and plz are not words.
Message 10 of 13
(4,558 Views)
