help needed to control stepper motor with built in drivers
I need a program to control my stepper motor. Can you please let me know if you can help me.
I haven't used LabView before. The data card  I am using is NI 9215. and using the following stepper motor:
http://www.sanyo-denki.com/sanmotion_db.aspx
 I need to control the steps (the motor has micro-step function) and the direction of the motor. Help required urgently.
Thanks a lot in advance
Message 1 of 10
(6,240 Views)
Urgent or not, if you are using the USB-9215, you have big problems since the 9215 does not have any outputs that you can use for controlling the stepper.
Message 2 of 10
(6,236 Views)
What Do I need to use? How do I go about it ?
Message 3 of 10
(6,227 Views)
Have you read the product sheet? You can control it with pulses, general I/O, or RS-485. For the first two, a device with a counter output or hardware timed digital I/O might work. The RS-485 requires either a RS-232->RS-485 converter or direct RS-485 device for the pc.
Click on the Products & Services link at the top of the page and you can search for hardware your lab may have. If you need to buy something, I suspect the RS-485 route would be the cheapest. NI's costs $149 but you can probably find something for much less.
Message 4 of 10
(6,223 Views)
What if I use NI 9263 module with it. Will that work?
Message 5 of 10
(6,170 Views)
uh... no
As Dennis plainly stated, you need a digital pulse train output and/or digital IO  or RS-485
Neither the USB 9215 nor the USB 9263 have these feeatures
Easiest method will probably be using RS-485 to send commands to the built-in motor driver.
Call NI and talk to an application engineer for help if you don't understand the data sheets
Tel: (888) 280-7645
Message 6 of 10
(6,137 Views)
What if I amonly looking for control using command pulses? As that option gives me 16 types of resolution for my step angle selection.
Message 7 of 10
(6,116 Views)
Your ability to control the motor with RS485 is almost certainly equal to using pulses. Read the manual.
If you insist on using pulses, then find a board with a counter output or digital output. In theory, you can also use an analog output if you are able to rewrite the existing code examples that use a counter/digital I/O. If you are up to that task, go for it.
Message 8 of 10
(6,109 Views)
Stepper motor with built in driver/controller
You can try UIM stepper motor driver/stepper motor controller
Shanghai United Intelligence Robot Technology Co., Ltd is a high-tech enterprise with researchers having USA education background.Registered in the Pudong Zhangjiang Hi-Tech Park, UI Robot is committed to devote to the development of robotic industry. Our robotic products have full independent intellectual property rights, and are protected under multiple domestic and foreign patents.
We advocates the philosophy of modular design and manufacture, that is, all the robots are one by one independent modules, all module uses a unified communications protocol to communicate with each other. In
addition, the mechanical interfaces of all modules are also simple and similar to each other. Different modules can be assembled flexibly to form different functions of the robot. With user friendly features, users do not need to understand how the specific module works at the backend; they just need to combine/separate modules according to the request, which can greatly improve the versatility and flexibility of the robot application and assembly.
R & D staff of UI Robot is from the United States, lead researchers have many years of research and development experience of industrial and civilian robot, they have worked on the military research and development of submarine detection robot, welding robot R & D and six foot snake-like hydraulic drive rescue robots.
Under UI Robot, we have developed a variety of robot components, such as wheeled and tracked mobile platform, comes with dedicated camera rotating head of the robot, military-level operation control box,small size, powerful functions intelligent stepper motor controller to CanBus protocol-based robot control system and so on. These components can be used to resolve related technical problems by themselves, or they can be combined together to form different functions of robotic products.
We hopes to develop new ideas and new realms in the filed of robotic research/manufacturing with advanced R&D concepts, so that the robot product can be as home computers, which plays an active role in the daily life of ordinary people. We desire to become the benchmark for robotics company worldwide, and push the robotics industry into an advanced era.
As a component of intelligent robot, we launched a series of stepping motor controllers. They are characterized by small size, strong driving ability, with full intellectual property rights, completely different from existing similar products in the market. The size of these motor controllers is 42mm * 42mm * 14mm (L*W*H), with the corresponding mounting flange, they can be directly mounted onto the 42/57/85/110 series of stepper motors. Our ultra-miniature and micro intelligent stepper motor drivers is categorized into parallel port series, UART (e.g. RS232) series, CAN series etc. Our stepper motor controller is the only product featured by small size, high intelligence and high driving performance products in domestic industry.
UI Robot Co. Ltd believes in "customer first, be creative and proactive", we will continue to provide our customers with great product and quality service.
Message 9 of 10
(6,073 Views)
spammer
Message 10 of 10
(6,070 Views)
