how I can use un PCMCIA card and create un .exe
Hi
I'm a new labview user, I need to now how I can acquire the signal of 4 sensors connected to PCMCI  card and create un .exe for use by someone who does not have LabView.
J'aimerai savoir comment acquérir le signaux de 4 capteurs branchées a une carte PCMCIA et postérieurement créer un .exe que sera utilisée pour quelqu'un que n'a pas labview.
Thanks ... merci
(3,472 Views)
What PCMCIA card?
You create an exe with the application builder. It's included with the Professinal versin of LabVIEW or you can buy it separately.
(3,466 Views)
HI,
I have 3 force sensors and 1 velocity sensor, all sensors will be connected to a box connections, (connection housing), and then a PCMCIA 6024E card makes the union to pc (labview 9.0).
thanks for your help.
(3,429 Views)
The 6024E is supported with DAQmx so you can use the DAQ Assistant or the lower level DAQmx functions. I would suggest the DAQmx Getting Started tutorials as a logical place to start.
(3,420 Views)
